unconfigure policy captive-portal
unconfigure policy captive-portal web-redirect redirect_index server server_id
Description
This command unconfigures a particular captive portal server. This disables the server from being used by an existing policy profile.
Syntax Description
web-redirect Unconfigures web-redirect.
redirect_index Specifies the web redirect index (range = 1–10).
server Unconfigures a server for the web redirect index.
server_id Specifies the server ID to disable.
Default
N/A
The following example unconfigures a particular captive portal server (index 2) in web-redirect (index 1):
unconfigure policy captive-portal web-redirect 1 server 2
This command was first available in ExtremeXOS 22.3.
Platform Availability
